TRENDnet's Wireless AC Easy-Upgrader, Model TEW-820AP, adds a Wireless AC network to a wireless or wired router. Simply plug the TEW-820AP into an available Ethernet port on the back of your existing router--and you're done. For your convenience the Wireless AC network is setup and pre-encrypted out of the box.
Easy Setup
Install the upgrader in minutes with a quick guided setup wizard
One Touch Connection
Securely connect Wireless AC enabled devices to the TEW-820AP at the touch of the Wi-Fi Protected Setup (WPS) button
Encrypted Wireless
For your convenience the Wireless AC network is pre-encrypted with its own unique password
Next Generation Wireless AC
Wireless AC provides uninterrupted HD video streaming in a busy connected home. You need a Wireless AC enabled device in order to connect to the TEW-820AP
Compact
The compact form factor easily fits next to your existing router
- TRENDnet TEW-820AP - bridge - Wi-Fi 5 - desktop
- Bridge
- Enclosure Type
- Desktop
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 433 Mbps
- Capacity
- Maximum number of configured SSIDs: 4
- DHCP, CSMA/CA
- MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, Access Point operational mode, Wi-Fi Multimedia (WMM) support, Access Point+, Wi-Fi Protected Setup (WPS), reset button, Wireless Client Mode
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Power
- AC 120/230 V (50/60 Hz)
- 6.5 cm x 6.7 cm x 2.1 cm
- 48 g
- 3-year warranty
- Bridge
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 433 Mbps
- Selectable Channels Qty
- 165
- Capacity
- DHCP, CSMA/CA
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, FCC
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
- 1 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 5 pin Micro-USB Type B (power only)
Aerial
- Aerial
- Internal
- Antenna Qty
- 1
- Gain Level
- 3 dBi
- Power Device
- External power adapter
- Voltage Required
- 2.3 Watt
- 6.5 cm
- 6.7 cm
- 2.1 cm
- 48 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
