TRENDnet's Outdoor 1.3 MP HD PoE+ Speed Dome Network Camera, model TV-IP450P, offers powerful 20x optical zoom, low light sensor, an IP66 weather rating, and endless 360 degree PTZ functionality. Record 1.3 Megapixel HD video (1280 x 960) at 30 fps in a space saving H.264 compression format. Manage up to 32 TRENDnet cameras with included complimentary software and mobile apps.
A separate mounting bracket is required--install with TRENDnet's TV-HC400, TV-HW400, TV-HP400, or TV-HN400.
Powerful zoom
20x optical zoom and 16x digital zoom combine for a total 320x zoom factor with autofocus. -
Low Light Vision
Provides visibility in extremely low light conditions (0.05 Lux rated). -
Endless PTZ
Endless 360° variable speed pan tilt zoom and user defined 3D zoom within the graphical user interface. -
Outdoor rated
Built for extreme environments with an IP66 weather rating and an operating temperature range of -30 – 65 °C (-22 – 149 °F). -
PoE+
Includes a PoE+ injector (30 Watts).
- TRENDnet TV TV-IP450P Outdoor 1.3 MP HD PoE+ Speed Dome Network Camera - network surveillance camera
- Network surveillance camera - pan / tilt / zoom - outdoor - weatherproof
- Audio
- Yes: two-way audio capability
- 22 cm x 22 cm x 30.5 cm
- 2.4 kg
- Connectivity Technology
- Wired
- Camera
- Optical Zoom
- 20 x
- Max Resolution
- 1280 x 960
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/3" - 1.3 MP
- Minimum Illumination
- 0.05 lux - colour , 0.01 lux - B&W
- Focal Length Control
- Motorized zoom
- Focal Length
- 4.7 mm - 94 mm
- Focus Adjustment
- Automatic, manual
- Lens Iris
- F/1.4-3.5
- Panning Range (degree)
- 360
- Tilting Range (degree)
- -5 to 90
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE Plus
- Digital noise reduction, sharpness control, remote control, white balance, saturation control, brightness control, contrast control, image mirror, heater, manually schedule recording, auto patrol, Motion Detection Technology, microSD card slot, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), 256 preset positions, tamper-detection, notification picture to E-mail, ONVIF V2.2 (Profile S) support, snapshot function
- 3-year warranty
- Environmental Parameters (operating)
- -30 °C - 65 °C; 0 - 90% (non-condensing) relative humidity
- Audio Support
- Wired
- 22 cm
- 22 cm
- 30.5 cm
- 2.4 kg
Camera
- Colour - pan / tilt / zoom - outdoor - weatherproof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 960
- Motion Detection
- Digital Zoom
- 16
- Exposure Range
- 1 sec - 1/10000 sec
- Video Capture
- 1280 x 960 @ 30 fps , 704 x 480 @ 30 fps
- Still Image Capture Resolution
- 1280 x 960, 704 x 480
Image Sensor
- 1.3 MP CMOS 1/3"
Lens Construction
- Motorized zoom
- Optical Zoom
- 20 x
- Focal Length
- 4.7 mm - 94 mm
- Lens Iris
- F/1.4-3.5
- Focus Adjustment
- Automatic, manual
- Horizontal Field of View (degree)
- 54
Panning
- Range (degree)
- 360
- Speed (degree/sec)
- Up to 300
Tilting
- Range (degree)
- -5 to 90
- Up to 200
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, PPPoE, SMB, IGMP, CIFS
- Supported Memory Cards
- microSD Card
- Included Accessories
- Power injector
- FCC, IP66
- Power Requirements
- PoE Plus
- Power Device
- 22 Watt
- Software Included
- Drivers & Utilities, TRENDnetVIEW Pro
- OS Required
- Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows 7 / Windows 8, Windows 8.1
- Limited warranty - 3 years
- -30 °C
- 65 °C
- Relative Humidity (operating)
- 0 - 90% (non-condensing)
