TRENDnet's Indoor/Outdoor 2MP H.265 WDR PoE IR Dome Network Camera, model TV-IP327PI, provides day and night surveillance with a night vision range of up to 30 meters (98 ft. ) This IR dome network camera delivers year-round surveillance with an IP67 weather rated housing to withstand outdoor environments. Record up to 2MP 1080p HD video at 30 fps in a space saving H.265 compression format.
Day/night HD surveillance
Powerful 2MP video in H.265 compression and 30 m (98 ft.) night vision provides 24-hour surveillance. -
Power over Ethernet (PoE)
PoE offers cost savings and the flexibility to install this outdoor IR dome camera up to 100 m (328 ft.) from the PoE source equipment. -
Outdoor ready
Built for outdoor environments with an IP67 weather rating and an operating temperature range of -30° - 60 °C (-22° - 140 °F).
- TRENDnet TV IP327PI - network surveillance camera - dome
- Network surveillance camera - fixed - dome - outdoor, indoor - vandal / weatherproof
- 11 cm x 11 cm x 8.25 cm
- 500 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/2.8" - 2 MP
- Minimum Illumination
- 0.01 lux , 0 lux - IR
- Focal Length
- 4 mm
- Lens Iris
- F/1.2
- Panning Range (degree)
- 0 to 355
- Tilting Range (degree)
- 0 to 75
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V / PoE
- Backlight Compensation (BLC), digital noise reduction, sharpness control, white balance, saturation control, brightness control, contrast control, e-mail alerts, Wide Dynamic Range (WDR), ONVIF support, Privacy Mask Function, PSIA, Motion Snapshot, tamper-detection, Smart IR, reset button, snapshot function, Internet Server Application Programming Interface (ISAPI), IP address filtering
- 3-year warranty
- Environmental Parameters (operating)
- -30 °C - 60 °C; 95% (non-condensing) relative humidity
- Form Factor
- Dome
- Wired
- 11 cm
- 11 cm
- 8.25 cm
- 500 g
Camera
- Colour - Day&Night - fixed - outdoor, indoor - vandal / weatherproof
- Digital Video Format
- MJPEG, H.264, H.265, H.265+, H.264+
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Digital Zoom
- 4
- Infrared LEDs
- Infrared Distance
- 30 m
- Video Capture
- 1920 x 1080 @ 30 fps , 640 x 480 @ 30 fps
Image Sensor
- 2 MP CMOS 1/2.8"
Lens Construction
- Focal Length
- 4 mm
- Lens Iris
- F/1.2
Panning
- Range (degree)
- 0 to 355
Tilting
- Range (degree)
- 0 to 75
- Network Interface
- Network Protocols
- DDNS, DHCP, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, PPPoE, SMB, Samba, QOS, DSCP, CIFS, LLTD, CGI, NFS
- Ports
- LAN/power - RJ-45
- Supported Memory Cards
- SDXC Memory Card, SDHC Memory Card, microSD Card
- Included Accessories
- Mounting kit
- UL, FCC, IP67, IEEE 802.3af, IEEE 802.1x
- Power Requirements
- DC 12 V / PoE - 1 A
- Power Device
- 9 Watt
- Software Included
- TRENDnetVIEW EVO, TRENDnet IPVIEW
- OS Required
- Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows Server 2012, Windows 8.1 / 10
- Limited warranty - 3 years
- -30 °C
- 60 °C
- Relative Humidity (operating)
- 95% (non-condensing)
