TRENDnet TU3-H4E 4-Port USB 3.0 Mini Hub
Quicklinx: 9CV4WS00 Mfr#: TU3-H4E
TRENDnet's 4-port USB 3.0 mini hub, model TU3-H4E, instantly adds four 5 Gbps SuperSpeed USB 3.0 ports to a computer. No CD installation required-simply plug in flash drives, storage enclosures, and other USB 3.0 devices at speeds ten times faster than a USB 2.0 connection. The TU3-H4E is also compatible with older USB 2.0 and 1.1 ports.
TRENDnet TU3 H4E - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 1.1, USB 2.0, USB 3.0
8 cm x 3.7 cm x 1.3 cm
35 g
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
Status Indicators
USB
4 x USB 3.0 Type A
4.5 Watt
1 x SuperSpeed USB cable - 14 cm
Plug and Play, FCC
8 cm
3.7 cm
1.3 cm
35 g
0 - 95% (non-condensing)
