TRENDnet's 4-Port USB 3.0 Hub provides four super speed USB 3.0 ports to connect flash drives, storage enclosures, cameras, and other USB 3.0 devices to your computer. With no drivers required, simply plug into any free USB 3.0 port on your PC or Mac to experience the time savings of transferring data at 5Gbps, 10 times faster than USB 2.0 speeds.
- TRENDnet TU3 H4 - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB 1.1, USB 2.0, USB 3.0
- 6 cm x 9.5 cm x 2.2 cm
- 68 g
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Built-in Devices
- Led panel
- 4 x USB 3.0 Type A , 1 x USB 3.0 Type B
- Power Device
- External power adapter
- 0.3 watt
- Cables Included
- 1 x USB cable - 1.8 m
- Plug and Play, FCC, RoHS
- 6 cm
- 9.5 cm
- 2.2 cm
- 68 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
