TRENDnet TU3-H4 4-Port USB 3.0 Hub
Quicklinx: 9CV3WS00 Mfr#: TU3-H4
TRENDnet's 4-Port USB 3.0 Hub provides four super speed USB 3.0 ports to connect flash drives, storage enclosures, cameras, and other USB 3.0 devices to your computer. With no drivers required, simply plug into any free USB 3.0 port on your PC or Mac to experience the time savings of transferring data at 5Gbps, 10 times faster than USB 2.0 speeds.
TRENDnet TU3 H4 - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB 1.1, USB 2.0, USB 3.0
6 cm x 9.5 cm x 2.2 cm
68 g
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Built-in Devices
Led panel
4 x USB 3.0 Type A , 1 x USB 3.0 Type B
External power adapter
0.3 Watt
1 x USB cable - 1.8 m
Plug and Play, FCC, RoHS
6 cm
9.5 cm
2.2 cm
68 g
0 - 90% (non-condensing)
