The TU-S9 USB to Serial converter allows you to connect a RS-232 serial device such as a modem to a USB port on your Desktop or Laptop PC.
 - TRENDnet TU-S9 - serial adapter - USB - RS-232
 - Serial adapter
- Form Factor
 - External
- Interface (Bus) Type
 - USB
- Ports
 - RS-232
 - 75 g
- Data Link Protocol
 - RS-232
- System Requirements
 - Apple MacOS 9.1 or later, Microsoft Windows 98SE/2000/ME/XP
 - 2-year warranty
 - Serial adapter
- Form Factor
 - External
 - USB
- Ports
 - RS-232
- Connectivity Technology
 - Wired
 - RS-232
 - 1 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
 - 1 x USB - 4 pin USB Type A
- Cables Included
 - 1 x USB cable (integrated) - 68.6 cm
 - Plug and Play, FCC
- OS Required
- System Requirements Details
 - Windows 98SE/2000/ME/XP - Pentium - 233 MHz - RAM 64 MB
 - 75 g
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
