Your basket is empty
TRENDnet TPL-420E2K Powerline 1200 AV2 Adapter Kit
Quicklinx: B5FLWS00 Mfr#: TPL-420E2K
Type: Bridge
Speed: 1.2Gbps
Connectivity: Wired
Pass-through Socket: No
5 in stock
£60.88 ex VAT
£73.05 inc VAT
Standard delivery Delivered within 3-5 working days
TRENDnet's Powerline 1200 AV2 Adapter Kit, model TPL-420E2K, comes with two Powerline adapters to create an extreme performance Powerline network using an existing electrical system. No CD installation required--encrypted TRENDnet adapters auto-connect out of the box. Plug in the first adapter and network it to your existing router. Plug in other adapters on the same electrical system and they auto-connect to the first adapter for immediate internet access.
Plug In Install
Simply plug in TRENDnet adapters! They auto-connect out of the box over an encrypted Powerline signal.
For Busy Homes
Powerline 1200 technology and a Gigabit port deliver incredibly fast and stable networking to seamlessly connect devices and stream 4K video.
Whole Home +
Multiple Input Multiple Output (MIMO) Powerline technology connects adapters over the same electrical system for homes up to 5,000 sq. ft. (465 sq. m).
Adapters
Includes two TPL-420E adapters
Powerline 1200
Extreme 1.2 Gbps Powerline networking over existing electrical lines use all three electrical wires: the live, neutral, and ground wires to achieve ground breaking networking throughput speeds**
Whole Home Coverage
Connects over electrical lines for homes up to 465 sq. m (5,000 sq. ft.) or over an electrical power line for a linear distance of 300 m (980 ft.)
MIMO with Beamforming Technology
Enhanced performance and range from MIMO with Beamforming technology
Gigabit Port
Gigabit port extends high performance wired connections
Network Stability
Ultra-stable Powerline networking is preferred by internet service providers
Multiple Adapters
Use up to 8 adapters to network an entire home
No CD Installation
Simply plug in the adapters--TRENDnet adapters auto-connect out of the box
Cross Compatible
Backward compatible with HomePlug AV compliant Powerline 600, 500, and 200 adapters
Compact
Compact form factor saves space around a crowded electrical outlet
Pre-Encrypted
For your convenience the adapter arrives pre-encrypted
Sync Button
Press the Sync button to change existing encryption keys
Energy Savings
Power Save mode reduces electrical consumption by up to 80%
TRENDnet TPL-420E2K - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug 1.0, HomePlug AV (HPAV) 2.0
Data Transfer Rate
1.2 Gbps
Nodes: 8
MIMO technology, integrated power socket, reset button, sync button
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, HomePlug 1.0, HomePlug AV 2.0, IEEE 1901
7.5 cm x 5.8 cm x 7.5 cm
118 g
Microsoft Windows Vista / XP / 7 / 8, Windows 8.1
Europe
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1.2 Gbps
Nodes: 8
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, HomePlug 1.0, HomePlug AV 2.0, IEEE 1901, FCC
Status Indicators
Status
LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
3.6 Watt
TRENDnet Powerline 1200 AV2 Adapter TPL-420E
1 x network cable - 1.5 m
Europe
Software Included
Drivers & Utilities
7.5 cm
5.8 cm
7.5 cm
118 g
Limited warranty - 3 years
0 - 90% (non-condensing)
Type: Bridge
Speed: 1.2Gbps
Connectivity: Wired
Brand: TRENDnet
Price Range Ex VAT: 50 - 100
