TPE-224WS 26-port Smart Switch integrates power over Ethernet (PoE) and network management features into a cost effective and scalable solution. The TPE-224WS reduces equipment cost by delivering data and power over existing network cable infrastructure. The switch offers advanced network management features such as VLAN and QoS to meet today's secured network applications.
- TRENDnet TPE-224WS Web Smart PoE Switch - switch - 24 ports - Managed - TAA Compliant
- Switch - 24 ports - Managed
- Enclosure Type
- 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100 (PoE) + 2 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- MAC Address Table Size
- 4K entries
- Remote Management Protocol
- SNMP, HTTP
- Flow control, full duplex capability, auto-negotiation, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, store and forward
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 31 cm x 4.4 cm
- 4.4 kg
- TAA Compliant
- 5-year warranty
- Enclosure Type
- Desktop 1U
- Subtype
- Fast Ethernet
- Ports
- PoE
- 4K entries
- SNMP, HTTP
- RAM
- 768 KB
- Status Indicators
- Port transmission speed, power, system, link/activity
- 24 x 100Base-TX RJ-45 PoE , 2 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- Rack Mounting Kit
- Included
- FCC
- TAA Compliant
- Software Included
- Drivers & Utilities
- 44 cm
- 31 cm
- 4.4 cm
- 4.4 kg
- Limited warranty - 5 years
- 0 °C
- 40 °C
- 10 - 90%
