TRENDnet's Home Smart Switch with Wireless Extender, model THA-101, is a combination smart electrical outlet and powerful N300 wireless extender.
Create a daily schedule to turn on/off the outlet to match your needs or to give the illusion that you're home. Place the THA-101 in an area of your home with low wireless coverage - the powerful built-in N300 wireless extender connects to your existing wireless router and broadcasts a strong wireless network.
Remote power control
Turn a light, fan, electronic device, or appliance On/Off from any mobile Internet connection. -
On/Off schedule
Create a weekly on/off schedule for a light, fan, or another device to match your needs or to give the illusion that you're home. -
No clutter
The compact form factor stays off the ground by plugging directly into an outlet. -
Power consumption
See how much power your device is consuming with real-time electrical consumption information listed within the app. -
Over current protection
Trips relay when current exceeds 16 Amps. -
Wireless extender
Extends the range of your existing wireless network. -
Wireless Coverage
Extended wireless coverage with MIMO antenna technology. -
One touch connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button. -
LED indicators
LED indicators convey device status.
- TRENDnet THA-101 Home Smart Switch - Wi-Fi range extender - Wi-Fi
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Power
- AC 120/230 V (50/60 Hz)
- 5.8 cm x 3.7 cm x 9.3 cm
- 156 g
- 3-year warranty
- 5.8 cm
- 3.7 cm
- 9.3 cm
- 156 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
- CSMA/CA
- Frequency Band
- 2.4 GHz
- Selectable Channels Qty
- 13
- Remote Power On, remote Power Off, MIMO technology, Wi-Fi Protected Setup (WPS), integrated power socket, reset button, over-current protection, on/off switches
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
- Authentication Method
- RADIUS
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Gain Level
- 2 dBi
- FCC
- Power Device
- Internal power supply
- Voltage Required
- 6 Watt
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
