Designed to handle multiple HD streams in a busy connected home, TRENDnet's high performance AC1200 Dual Band Wireless Router, model TEW-813DRU, creates two concurrent wireless networks - a high performance 867 Mbps Wireless AC network and a 300 Mbps Wireless N network to connect common wireless devices.
Easy Setup
Get up and running in minutes with the intuitive guided setup
One Touch Connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
USB Share Port
Plug in a USB flash or storage drive to share content across the network
Access Control
Encrypted Wireless
For your convenience the router arrives pre-encrypted with its own unique password
Guest Network
Create a secure, isolated network for guest internet access only
Parental Controls
Control access to specific websites or types of content
Next Generation Wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home
Simultaneous Dual Band
High speed 867 Mbps Wireless AC + 300 Mbps Wireless N
Gigabit Ports
Gigabit ports extend high performance wired connections
Wireless Coverage
Extensive wireless coverage with MIMO antenna technology
Backward Compatible
Compatible with legacy wireless devices
Targeted Beamforming
Increased real-time performance by directing stronger wireless to your specific location
- For maximum performance of up to 867 Mbps use with an 867 Mbps 802.11ac wireless adapter.
** Maximum wireless signal rates are referenced from IEEE 802.11 theoretical specifications. Actual data throughput and cov-erage will vary depending on interference, network traffic, building materials and other conditions.
Easy setup
Get up and running in minutes with the intuitive guided setup. -
One touch connection
Securely connect to the router at the touch of the Wi-Fi protected setup (WPS) button. -
USB share port
Plug in a USB flash or storage drive to share content across the network. -
Encrypted wireless
For your convenience the router arrives pre-encrypted with its own unique password. -
Guest network
Create a secure, isolated network for guest Internet access. -
Parental controls
Control access to specific websites or types of content. -
Next generation wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home. -
Simultaneous dual band
It features high speed 867 Mbps Wireless AC and 300 Mbps Wireless N. -
Gigabit ports
Gigabit ports extend high performance wired connections. -
Wireless coverage
This router features extensive wireless coverage with MIMO antenna technology. -
Targeted beamforming
Increased real-time performance by directing stronger wireless to your specific location.
- TRENDnet TEW-813DRU - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 867 Mbps
- DDNS
- Firewall protection, NAT support, Stateful Packet Inspection (SPI), dynamic DNS server, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, URL filtering, parental control, IP address filtering, Wi-Fi Protected Setup (WPS), Samba support, FTP server, pre-encrypted
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac (draft 2.0)
- Power
- AC 120/230 V (50/60 Hz)
- 4.5 cm x 12 cm x 16.4 cm
- 260 g
- 3-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 867 Mbps
- DDNS
- Encryption Algorithm
- WPA2
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac (draft 2.0), ETSI, FCC
- Status Indicators
- Power, wireless, DMZ/Internet, USB, WPS
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Gain Level
- 6 dBi
- Power Device
- External power adapter
- Voltage Required
- 16.5 Watt
- Cables Included
- 1 x network cable - 1.5 m
- Software Included
- Drivers & Utilities
- 4.5 cm
- 12 cm
- 16.4 cm
- 260 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
