Product
TRENDnet TEW-804UB AC600 Dual Band Wireless USB Adapter
Quicklinx: 999PWS00 Mfr#: TEW-804UB
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11ac (draft 2.0), IEEE 802.11b, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
£15.95 ex VAT
£19.14 inc VAT
TRENDnet's AC600 Dual Band Wireless USB Adapter, model TEW-804UB, connects a Windows or Mac computer to a wireless AC network. Connect to a Wireless AC network at up to 433 Mbps or to a Wireless N network at up to 150 Mbps. This high performance adapter comes in a compact form factor.
Easy Setup
Get up and running in minutes with the intuitive guided setup
One Touch Connection
Securely connect to a wireless network at the touch of the Wi-Fi Protected Setup (WPS) button
Security
Encrypted Wireless - Supports the latest encryptions standards (up to WPA2)
Performance
Next Generation Wireless AC - 802.11ac provides HD video streaming in a busy connected home
Dual Band
High speed 433 Mbps Wireless AC or 150 Mbps Wireless N network connection
Backward Compatible
Compatible with older wireless devices
Operating Systems
Compatible with Windows® and Mac® operating systems
TRENDnet TEW-804UB - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
1.9 cm x 3.8 cm x 0.8 cm
5 g
802.11b, 802.11a, 802.11g, 802.11n, 802.11ac (draft 2.0)
Data Transfer Rate
433 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, USB 2.0, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
3 years warranty
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
433 Mbps
Frequency Band
2.4 GHz, 5 GHz
Aerial
Antenna
Internal
Encryption Algorithm
WPA2
FCC
1.9 cm
3.8 cm
0.8 cm
5 g
Limited warranty - 3 years
0 - 95% (non-condensing)
Protocol: IEEE 802.11ac (draft 2.0)
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: TRENDnet
Price Range Ex VAT: 0 - 50
