TRENDnet's TEG-2248WS 52-port Gigabit Web-Based Smart Switch is the ideal switch for network segmenting. It has 48 10/100Mbps and 2 10/100/1000Mbps RJ45 ports with Auto-Sensing and Auto-MDIX feature for easy installation. This switch also has 2 Mini-GBIC ports that accept optional gigabit fiber modules for greater flexibility. The TEG-2248WS supports web browser configuration; Network Administrators can use web browsers to configure port speed, port-based VLAN, QoS, Trunking and also to monitor each port's status. TRENDnet's powerful and easy-to-use TEG-2248WS is designed to reduce unnecessary broadcast traffic and enhance network security.
 - TRENDnet TEG 2248WS - switch - 48 ports - Managed - rack-mountable
 - Switch - 48 ports - Managed
- Enclosure Type
 - Rack-mountable 1U
- Subtype
 - Fast Ethernet
- Ports
 - 48 x 10/100 + 2 x SFP + 2 x 10/100/1000
- MAC Address Table Size
 - 4K entries
- Remote Management Protocol
 - HTTP
 - Flow control, trunking, VLAN support, store and forward
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
- Power
 - AC 120/230 V (50/60 Hz)
 - 44 cm x 20 cm x 4.4 cm
 - 2.6 kg
 - 5-year warranty
- Enclosure Type
 - Rack-mountable 1U
- Subtype
 - Fast Ethernet
- Ports
 - 4K entries
 - HTTP
- Flash Memory
 - 1.5 MB
- Status Indicators
 - Power, system, link/activity
 - 2 x 1000Base-T RJ-45 , 48 x 100Base-TX RJ-45 , 2 x SFP (mini-GBIC)
- Power Device
 - Internal power supply
- Voltage Required
 - 26 Watt
- Rack Mounting Kit
 - Included
 - FCC Class A certified, cUL, VCCI Class A ITE, IEC 60950, UL 60950
 - 44 cm
 - 20 cm
 - 4.4 cm
 - 2.6 kg
 - Limited warranty - 5 years
 - 0 °C
 - 40 °C
 - 10 - 90%
