The compact 8-Port 10/100 Mbps GREENnet Switch, model TE100-S8, offers plug and play switching reliability and reduced power consumption. Embedded GREENnet technology reduced power consumption by up to 40% out of the box, with no management requirement. This switch offers speeds of up to 200 Mbps per port and total switching capacity of 1.6 Gbps.
Easy Setup
Plug and play out of the box
Compact
Compact design fits in a crowded desktop
Traffic Management
Non-blocking wire-speed architecture
Ethernet Ports
Up to 200 Mbps per port and total switching capacity of 1.6 Gbps
Power Savings
Power saving GREENnet technology reduces power consumption by up to 40%
 - TRENDnet TE100 S8 - switch - 8 ports
 - Switch - 8 ports
- Subtype
 - Fast Ethernet
- Ports
 - 8 x 10/100
- Performance
 - Switching fabric bandwidth: 1.6 Gbps
- MAC Address Table Size
 - 1K entries
 - Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, GREENnet technology
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
- Power
 - AC 120/230 V (50/60 Hz)
 - 14 cm x 7.5 cm x 2.8 cm
 - 126 g
 - 3-year warranty
 - Switch - 8 ports
- Enclosure Type
 - Desktop
- Subtype
 - Fast Ethernet
- Ports
 - 8 x 10/100
- Performance
 - 1K entries
- RAM
 - 56 KB
 - 8 x 100Base-TX RJ-45
- Power Device
 - External power adapter
- Voltage Required
 - 1.4 Watt
 - Plug and Play, FCC
 - 14 cm
 - 7.5 cm
 - 2.8 cm
 - 126 g
 - Limited warranty - 3 years
 - 0 °C
 - 50 °C
 - 0 - 90% (non-condensing)
