TRENDnet's VDV & USB cable tester, model TC-NT3, is a comprehensive cable tester for network professionals. It accurately tests a variety of voice, data, video, and USB cables. The TC-NT3 identifies proper, severed, short circuit, and cross connected pins for cable distances of up to 300 meters.
Quick test mode issues a pass/fail for large test batches.
All components fit into a convenient travel case.
TX/RX troubleshooting
Displays separate TX and RX results for more efficient troubleshooting. -
Local and remote testing
A master unit facilitates loop testing and a detachable remote terminal unit allows for cable testing in locations away from the master unit. -
Continuous scan
Continuous scan mode is design to accommodate testing with cable ends in different locations. -
Manual scan
Manual scan is well suited for loop back cable testing. -
Quick test mode
Designed to quickly test large cable quantities, quick test mode identifies a given cable type and then immediately issues a pass/fail for the same cable type. -
Blinking hub/switch mode
Designed to confirm which port on a hub/switch a given cable is networked to, blinking hub/switch mode causes the connected network port's LED indicator to blink.
 - TRENDnet TC-NT3 - network tester
 - Network tester
- Cable Types
 - CAT3, CAT4, CAT5, CAT5e, coax, CATV, CAT6, CAT6a, CAT6e, CAT7, CAT8, CAT3e
- Tests, Tools and Measurements
 - Tests for crossed wires, short circuit, grounding
 - Cable tone generator
 - 11.7 cm x 6.7 cm x 2.7 cm
 - 114 g
 - 1 year
 - Network tester
- Media
 - Copper
- Cable Types
- Included Accessories
 - Carrying pouch, 2 x RJ-45 to F-connector adapters
- Cables Included
 - 1 x RJ-45 to RJ-45 patch cable - 15 m
- Connectors
 - RJ-45, RJ-12, RJ-11, 9 pin USB type A, 9 pin USB type B, RJ-9, RJ-14, RJ-25, RJ-61
- Warranty
 - 1 year
- Voltage
 - 9 V
- Included Qty
 - 0
- Required Qty
 - 1
 - 11.7 cm
 - 6.7 cm
 - 2.7 cm
 - 114 g
 - 0 °C
 - 50 °C
 - 0 - 95% (non-condensing)
