TRENDnet's Gigabit Ultra PoE+ Injector, model TPE-117GI, combines electrical power with a Gigabit network connection to produce a Gigabit Ultra Power over Ethernet Plus signal. Auto-sensing technology conveniently delivers the correct wattage needed to power your Ultra PoE devices and PoE+ devices. Use an existing open port from a non-PoE switch to save installation and equipment costs when installing TRENDnet PoE access points and IP cameras in remote locations.
PoE
Supplies a PoE device with PoE (15.4 watts), PoE+ (30 watts), or Ultra PoE (60 watts) power. -
Plug and Play
Plug and play PoE network devices - no configuration needed. -
Installation flexibility
Wall-mount design and a sturdy metal enclosure accommodates most installations scenarios. -
LED indicators
LED indicators confirm PoE and network connectivity. -
Auto-sensing technology delivers up to 60 watts to an Ultra PoE device with backwards compatibility for 802.3at PoE+ (30 watts) and 802.3af PoE (15 watts) devices.
- TRENDnet TPE-117GI - PoE injector - 60 watt
- PoE injector - external
- 185 g
- Power Capacity
- 60 watt
- Input Connectors
- 1 x power
- Output connectors
- 1 x RJ-45
- Included Accessories
- Power adapter
- 12 cm x 7.5 cm x 2.2 cm
- 3-year warranty
- Input Voltage Range
- AC 100 - 240 V
- Frequency Required
- 50 - 60 Hz
- Input Connectors
- 1 x power
- Power Output Connectors Details
- 1 x RJ-45
- Power Capacity
- 60 watt
- 1 x Gigabit LAN - RJ-45
- Power adapter
- Cables Included
- Power cable - external
- Wall mountable, LED indicators, Auto-Sensing Technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3at, IEEE 802.3bt (draft), Plug and Play, FCC
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 0 - 95% (non-condensing)
- 12 cm
- 7.5 cm
- 2.2 cm
- 185 g
