The Gigabit Power over Ethernet injector, model TPE-113GI, combines electrical power with a gigabit network connection to produce a Gigabit Power over Ethernet (PoE) signal. Connect this device to a non-PoE switch and then run an Ethernet cable for up to 100 meters to network PoE devices.
No need to buy a PoE switch - use an existing open port from a non-PoE switch to save installation and equipment costs when installing TRENDnet PoE access points and IP cameras in remote locations. This compact device safeguards valuable network equipment with short circuit protection. Quickly create an integrated PoE and non-PoE network at gigabit speeds.
- TRENDnet TPE-113GI - PoE injector - 15.4 Watt
- PoE injector - external
- 45 g
- Input Voltage
- AC 100-240 V
- Power Capacity
- 15.4 Watt
- Input Connectors
- 1 x power
- Output connectors
- 1 x RJ-45
- Included Accessories
- Power adapter
- 7 cm x 4.5 cm x 2.5 cm
- 3-year warranty
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Input Connectors
- 1 x power
- 15.4 Watt
- Power Output Connectors Details
- 1 x RJ-45
- Power Capacity
- 15.4 Watt
- 1 x Gigabit LAN - RJ-45
- Power adapter
- Wall mountable, short-circuit protection
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, Plug and Play, FCC
- Limited warranty - 3 years
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- 7 cm
- 4.5 cm
- 2.5 cm
- 45 g
