TRENDnet Gigabit PoE+ Repeater/Amplifier
Quicklinx: FQ85WS00 Mfr#: TPE-E110
TRENDnet's model TPE-E110 extends and amplifies a Gigabit PoE or PoE+ network connection to a remote location. It auto-detects a PoE or PoE+ signal and extends it an additional meters from the PoE device. A rugged metal enclosure and no need for an external power adapter facilitate remote installations.
TRENDnet TPE-E110 - repeater - 10Mb LAN, 100Mb LAN, 1GbE
Repeater - RJ-45 / RJ-45
External
Cabling Type
10Base-T, 100Base-TX, 1000Base-T
Data Transfer Rate
2 Gbps
Max Transfer Distance
100 m
Power Over Ethernet (PoE)
PoE+
12.5 cm x 7.5 cm x 3.3 cm
306 g
3-year warranty
Repeater
External
Wired
Cabling Type
Data Transfer Rate
2 Gbps
MAC Address Table Size
2K entries
100 m
Status Indicators
IGMP snooping, half duplex mode, full duplex mode, wall mountable, cascadable, rugged, 96KB packet buffer, metal housing
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
1 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ input) - RJ-45 female , 1 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ output) - RJ-45 female
FCC
PoE+
2 Watt
12.5 cm
7.5 cm
3.3 cm
306 g
Limited warranty - 3 years
45 °C
0 - 90% (non-condensing)
