TRENDnet's corner mount bracket, model TV-HN400, installs a TRENDnet SpeedDome series network camera 30 cm (12-inch) off of an outside corner surface. This rugged powder-coated aluminum mount features a suspension point from which to hang the camera during installation and mounting hardware.
Construction
Rugged powder-coated aluminum construction. -
Seal ring
Seal ring maintains waterproof seal against flat surface. -
Suspension point
Offers a suspension point from which to hang the camera during installation.
- TRENDnet TV-HN400 - camera dome mounting bracket
- Product Type
- Camera dome mounting bracket
- Placing / Mounting
- Corner mountable
- Product Material
- Aluminium
- 17.68 cm x 41.95 cm x 19.4 cm
- 2.2 kg
- 1-year warranty
- Designed For
- TV TV-IP450P Outdoor 1.3 MP HD PoE+ Speed Dome Network Camera, TV-IP450PI Outdoor 1.3 MP HD PoE IR Speed Dome Network Camera
- Product Type
- Corner mountable
- Product Material
- Aluminium
- 17.68 cm
- 41.95 cm
- 19.4 cm
- 2.2 kg
- Mounting Kit
- Included
- Powder coated, rugged
- Limited warranty - 1 year
- Designed For
- TRENDnet TV TV-IP450P Outdoor 1.3 MP HD PoE+ Speed Dome Network Camera, TV-IP450PI Outdoor 1.3 MP HD PoE IR Speed Dome Network Camera
