The Outdoor Arrestor Kit provides lightning protection for your wireless equipment. By adding a simple arrestor to your wireless antenna, you can reduce the costs in damaged switches, access points, or other network devices. Simply connect the Outdoor Arrestor Kit directly inline between your Access Point and your outdoor antenna cable, and connect the ground wire to a ground pole.
