TRENDnet Antenna Surge Arrestor +
Quicklinx: B4FMWS00 Mfr#: TEW-ASAK
The Outdoor Arrestor Kit provides lightning protection for your wireless equipment. By adding a simple arrestor to your wireless antenna, you can reduce the costs in damaged switches, access points, or other network devices. Simply connect the Outdoor Arrestor Kit directly inline between your Access Point and your outdoor antenna cable, and connect the ground wire to a ground pole.
TRENDnet TEW ASAK Outdoor Arrestor Kit - lightning arrester
Lightning arrester
Lightning arrester
Cabling & Wiring
Connector Provided
1 x N-Series connector
