TRENDnet 8-Port USB/PS/2 Rack Mount KVM Switch
Quicklinx: BXT5WS00 Mfr#: TK-803R
Type: KVM switch
Ports: 8
Connectivity: KVM
£106.67 ex VAT
£128.00 inc VAT
The 8-port USB KVM switch lets you manage multiple computers with just one set of keyboard, monitor and mouse. This rack mount device supports USB and PS/2 interface on the console side and USB only on the PC side. Popular hardware platforms such as PC, Linux and Mac are supported. Users can switch between PCs using hot-key or push button for flexible management. Users can also hot-plug PCs on the fly to avoid downtime. The 8-port USB KVM switch is the perfect choice for managing multiple PC's.
TRENDnet TK 803R - KVM switch - 8 ports - rack-mountable - TAA Compliant
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user
Firmware upgradable
USB 1.1
40.7 cm x 16.5 cm x 4.5 cm
1.8 kg
Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 98SE/2000/ME/XP
TAA Compliant
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2
Max Resolution
2048 x 1536
Firmware upgradable
USB 1.1
Status Indicators
Active, select
8 x KVM DB-15 , 1 x VGA HD-15 , 1 x mouse (PS/2) , 1 x mouse (USB) Type A , 1 x keyboard (PS/2) , 1 x keyboard (USB) Type A
External power adapter
Rack Mounting Kit
Included
Plug and Play, FCC, RoHS
TAA Compliant
40.7 cm
16.5 cm
4.5 cm
1.8 kg
0 - 80%
Type: KVM switch
Ports: 8
Connectivity: KVM
Brand: TRENDnet
