TRENDnet 8-Port Gigabit PoE+ Switch
Quicklinx: FQ8WWS00 Mfr#: TPE-TG82g
The 8-Port Gigabit PoE+ Switch, model TPE-TG82g, delivers data and power over existing Ethernet cables to Power over Ethernet (PoE) devices such as Access Points and IP Cameras. It supports both PoE and PoE+ devices with a 61W PoE budget. Plug and Play this sturdy metal switch for reliable high-speed PoE networking.
  • PoE power
    A 61W PoE power budget supports up to eight Power over Ethernet devices.
  • Gigabit Ethernet
    Eight gigabit ports provide a 16Gbps switching capacity to support edge network installations.
  • Compact design
    With a compact and lightweight housing design, this switch is well-suited for desktop installations. Its fanless design is ideal for quiet environments that require silent operation.
TRENDnet TPE TG82G - switch - 8 ports - TAA Compliant
Switch - 8 ports
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
61 W
Performance
Switching capacity: 16 Gbps , Forwarding performance (64-byte packet size): 11.9 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Half duplex mode, full duplex mode, GREENnet technology, fanless, metal housing
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
AC 120/230 V (50/60 Hz) 1.2 A
15 cm x 9.5 cm x 3 cm
400 g
TAA Compliant
Switch - 8 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
61 W
Performance
8K entries
Jumbo Frame Support
9KB
Status Indicators
Port status
8 x 1000Base-T RJ-45 PoE+
External power adapter
Electric Current Required
1.2 A
36 Watt
Plug and Play, FCC
TAA Compliant
15 cm
9.5 cm
3 cm
400 g
Limited warranty - lifetime , Limited warranty - power supply and fans - 1 year
90% (non-condensing)
