TRENDnet 8-Port Gigabit Long Range PoE+ Switch
Quicklinx: FQ94WS00 Mfr#: TPE-LG80
The TPE LG80 delivers data and power to PoE devices such as access points, VoIP phones, and IP cameras. It supports both PoE and PoE+ devices. Its fanless design is perfect for quiet environments that require silent operation.
  • Port isolation
    Ideal for surveillance networking applications, the DIP switch also enables port isolation.
  • LED indicators
    LED indicators convey PoE and port status.
TRENDnet TPE LG80 - switch - 8 ports - unmanaged - TAA Compliant
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
65 W
Performance
Switching capacity: 16 Gbps , Forwarding performance (64-byte packet size): 11.9 Mpps
MAC Address Table Size
4K entries
Jumbo Frame Support
9KB
VLAN support, half duplex mode, full duplex mode, wall mountable, QoS, fanless, built-in DIP switch, port isolation, CoS, metal housing, long range PoE+ up to 200m at 10Mbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3p, IEEE 802.3at, IEEE 802.3az
24 cm x 10.5 cm x 2.7 cm
592 g
TAA Compliant
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
65 W
Performance
4K entries
Jumbo Frame Support
9KB
RAM
192 KB
Status Indicators
Power, alert, PoE, link/activity, link/speed
8 x Gigabit LAN RJ-45 PoE+
External power adapter
Power Provided
55 V - 1.3 A
70.6 Watt
Plug and Play, FCC, RoHS, WEEE
TAA Compliant
24 cm
10.5 cm
2.7 cm
592 g
Limited warranty - lifetime
0 - 90% (non-condensing)
