The compact 8-Port Gigabit GREENnet Switch provides high bandwidth performance, ease of use and reliability, all while reducing power consumption by up to 70%. GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings.
Boost your office efficiency and eliminate network congestion with Gigabit speeds. Plug and Play this sturdy metal switch for reliable high speed network connectivity.
- TRENDnet TEG S81g 8-Port Gigabit GREENnet Switch - switch - 8 ports
- Switch - 8 ports
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Forwarding performance: 16 Gbps
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9216 bytes
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, MAC address filtering, half duplex mode, full duplex mode, Jumbo Frames support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 17.1 cm x 10 cm x 3.1 cm
- 190 g
- 3-year warranty
- Switch - 8 ports
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- 8K entries
- 9216 bytes
- Status Indicators
- Port transmission speed, power, link/activity
- 8 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- 3.5 Watt
- FCC, RoHS, WEEE
- 17.1 cm
- 10 cm
- 3.1 cm
- 190 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
