TRENDnet's 8-Port Gigabit GREENnet PoE+ Switch, model TPE-TG80g, reduces equipment and installation costs by delivering data and power over existing Ethernet cables. This unmanaged switch offers eight Gigabit PoE+ ports which supply up to 30 watts of power per port for devices such as high power wireless access points, PTZ (Pan / Tilt / Zoom) Internet cameras, and VoIP telephony systems.
Auto sensing technology delivers 30 watts to 802.3at PoE+ devices (up to 3 devices), 15 watts to 802.3af PoE devices, and only data to non-PoE devices. GREENnet technology reduces energy consumption by up to 75% when the switch is not in use. Boost office efficiency and reduce network congestion with a total switching capacity of 16 Gbps. LED indicators display device status for efficient troubleshooting. This switch comes in a sturdy metal case and quickly adds PoE+, PoE, and non-PoE devices to your network.
- TRENDnet TPE TG80G GREENnet PoE+ Switch - switch - 8 ports - TAA Compliant
- Switch - 8 ports
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 (PoE+)
- Power Over Ethernet (PoE)
- PoE+
- Performance
- Switching capacity: 16 Gbps , Forwarding performance: 1.49 Mpps
- MAC Address Table Size
- 1K entries
- Jumbo Frame Support
- 9KB
- Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, GREENnet technology, Energy Efficient Ethernet, 96KB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 14.2 cm x 9.5 cm x 3 cm
- 400 g
- TAA Compliant
- Limited lifetime warranty
- Switch - 8 ports
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- Performance
- 1K entries
- 9KB
- Status Indicators
- Port transmission speed, power, PoE, link/activity
- 8 x 1000Base-T RJ-45 PoE+
- Power Device
- Internal power supply
- Voltage Required
- 120 Watt
- Plug and Play, FCC
- TAA Compliant
- 14.2 cm
- 9.5 cm
- 3 cm
- 400 g
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
