TRENDnet 8-port Gigabit GREENnet PoE Switch
Quicklinx: 9YNGWS00 Mfr#: TPE-TG80G
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 1Gbps
Managed: No
POE: PoE+
Hurry, only 2 left in stock!
£138.96 ex VAT
£166.75 inc VAT
TRENDnet's 8-Port Gigabit GREENnet PoE+ Switch, model TPE-TG80g, reduces equipment and installation costs by delivering data and power over existing Ethernet cables. This unmanaged switch offers eight Gigabit PoE+ ports which supply up to 30 watts of power per port for devices such as high power wireless access points, PTZ (Pan / Tilt / Zoom) Internet cameras, and VoIP telephony systems.
Auto sensing technology delivers 30 watts to 802.3at PoE+ devices (up to 3 devices), 15 watts to 802.3af PoE devices, and only data to non-PoE devices. GREENnet technology reduces energy consumption by up to 75% when the switch is not in use. Boost office efficiency and reduce network congestion with a total switching capacity of 16 Gbps. LED indicators display device status for efficient troubleshooting. This switch comes in a sturdy metal case and quickly adds PoE+, PoE, and non-PoE devices to your network.
TRENDnet TPE TG80G GREENnet PoE+ Switch - switch - 8 ports - TAA Compliant
Switch - 8 ports
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
Performance
Switching capacity: 16 Gbps , Forwarding performance: 1.49 Mpps
MAC Address Table Size
1K entries
Jumbo Frame Support
9KB
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, GREENnet technology, Energy Efficient Ethernet, 96KB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
14.2 cm x 9.5 cm x 3 cm
400 g
TAA Compliant
Switch - 8 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
1K entries
Jumbo Frame Support
9KB
Status Indicators
Port transmission speed, power, PoE, link/activity
8 x 1000Base-T RJ-45 PoE+
Internal power supply
120 Watt
Plug and Play, FCC
TAA Compliant
14.2 cm
9.5 cm
3 cm
400 g
Limited warranty - lifetime
0 - 90% (non-condensing)
Ports: 8
Managed: No
POE: PoE+
Brand: TRENDnet
