TRENDnet's 8-port Gigabit GREENnet PoE+ Switch, model TPE-TG81g, reduces equipment and installation costs by delivering data and power over existing Ethernet cables. This unmanaged switch offers eight Gigabit PoE+ ports which supply up to 30 watts of power per port for devices such as high power wireless access points, PTZ (Pan/Tilt/Zoom) Internet cameras, and VoIP telephony systems.
This rack mountable switch features an internal power supply. Auto sensing technology delivers 30 watts to 802.3at PoE+ devices (up to 3 devices), 15 watts to 802.3af PoE devices, and only data to non-PoE devices. GREENnet technology reduces energy consumption by up to 75% when the switch is not in use. Boost office efficiency and reduce network congestion with a total switching capacity of 16 Gbps. LED indicators display device status for efficient troubleshooting. This switch comes in a sturdy metal case and quickly adds PoE+, PoE, and non-PoE devices to your network.
 - TRENDnet TPE TG81g GREENnet PoE+ Switch - switch - 8 ports - rack-mountable - TAA Compliant
 - Switch - 8 ports
- Enclosure Type
 - Rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - 8 x 10/100/1000 (PoE+)
- Power Over Ethernet (PoE)
 - PoE+
- Performance
 - Switching capacity: 16 Gbps , Forwarding performance: 1488000 pps
- MAC Address Table Size
 - 2K entries
- Jumbo Frame Support
 - 9KB
 - Flow control, auto-sensing per device, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, GREENnet technology, fanless, 96KB packet buffer
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
- Power
 - AC 90 - 260 V (50/60 Hz) 1 A
 - 26.6 cm x 16 cm x 4.4 cm
 - 1.36 kg
- TAA Compliant
 - Limited lifetime warranty
 - Switch - 8 ports
- Enclosure Type
 - Desktop, rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE+
- Performance
 - 2K entries
 - 9KB
- Status Indicators
 - Power, PoE, link/activity
 - 8 x 1000Base-T RJ-45 PoE+
- Power Device
 - Internal power supply
- Voltage Required
- Electric Current Required
 - 1 A
 - 122 Watt
- Rack Mounting Kit
 - Included
 - Plug and Play, FCC
- TAA Compliant
 - 26.6 cm
 - 16 cm
 - 4.4 cm
 - 1.36 kg
 - Limited warranty - lifetime
 - 0 °C
 - 45 °C
 - 0 - 90% (non-condensing)
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 90 °C
