TRENDnet 8-Port Gigabit Full Power PoE+Switch
Quicklinx: FQ91WS00 Mfr#: TPE-TG80F
TRENDnet's Gigabit PoE+ switch reduces equipment and installation costs by delivering data and power over existing Ethernet cables. This full power PoE switch features eight Gigabit PoE+ ports, supplying power for devices such as high-power wireless access points, IP cameras, and VoIP phone systems.
TRENDnet TPE TG80F - switch - 8 ports - rack-mountable - TAA Compliant
Switch - 8 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
240 W
Performance
Switching capacity: 16 Gbps , Forwarding performance (64-byte packet size): 11.9 Mpps , Buffer memory: 192 KB
MAC Address Table Size
4K entries
Jumbo Frame Support
9KB
Half duplex mode, full duplex mode, fanless, metal housing
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
26.5 cm x 18.4 cm x 4.4 cm
1.7 kg
TAA Compliant
Switch - 8 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
240 W
Performance
4K entries
Jumbo Frame Support
9KB
Status Indicators
Port status
8 x 1000Base-T RJ-45 PoE+
Internal power supply
Rack Mounting Kit
Included
FCC, ETL, CE/EMC
TAA Compliant
26.5 cm
18.4 cm
4.4 cm
1.7 kg
Limited warranty - lifetime , Limited warranty - power supply and fans - 1 year
90% (non-condensing)
