Brand
TRENDnet 8-Port Gigabit EdgeSmart PoE+ Switch (61W)
Quicklinx: FQ8TWS00 Mfr#: TPE-TG82ES
£73.06 ex VAT
£87.67 inc VAT
TRENDnet's 8-Port Gigabit EdgeSmart PoE+ Switch, model TPE-TG82ES, is a cost-effective desktop PoE managed switch solution for high-speed gigabit PoE+ applications. This EdgeSmart switch features the most commonly used managed switch features, reducing unnecessary switch complexity. The web-based management interface offers features for traffic control, LACP, RSTP, VLAN, QoS, and monitoring. TRENDnet's TPE-TG82ES desktop PoE managed switch provides eight gigabit PoE+ ports for connecting devices such as wireless access points, IP cameras, and VoIP handsets.
  • EdgeSmart management
    Provides an easy-to-use web-based management interface for reduced switch configuration complexity and offers a combination of more commonly used SMB management features for easy deployment.
  • Integration flexibility
    Managed features include loopback detection, RSTP, LACP, VLAN, IGMP Snooping, and QoS for flexible network integration.
  • PoE+ power
    A 64W PoE power budget supplies up to eight Power over Ethernet devices.
TRENDnet TPE TG82ES - switch - 8 ports - smart - TAA Compliant
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
64 W
Performance
Switching capacity: 16 Gbps , Forwarding rate: 11.9 Mpps
VLAN groups: 32 , Multicast groups: 32
MAC Address Table Size
4K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP
IGMP snooping, port mirroring, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, firmware upgradable, Weighted Fair Queuing (WFQ), wall mountable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, reset button, bandwidth control, fanless, short circuit protection, Class of Service (CoS), Strict Priority (SP), tagged VLAN, PoE overcurrent protection, cable test, Voice VLAN, Private VLAN, loopback detection, port-based QoS, block unknown multicast, Asymmetric VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3at, IEEE 802.3az
AC 120/230 V (50 - 60 Hz) 1.2 A
17.1 cm x 9.78 cm x 2.86 cm
423 g
TAA Compliant
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
64 W
Performance
4K entries
Jumbo Frame Support
9KB
Routing Protocol
RAM
192 KB
Status Indicators
Power, PoE, link/activity
8 x Gigabit LAN RJ-45 PoE+ - 30 W
External power adapter
Power Provided
54 V - 1.67 A
Electric Current Required
1.2 A
68.6 Watt
MTBF
730,455 hours
FCC, RoHS, WEEE
TAA Compliant
17.1 cm
9.78 cm
2.86 cm
423 g
90% (non-condensing)
