TPE-S44 Wireless PoE Access Point is today's link to Wireless Technology. Compliant with the IEEE Wireless Networking Standard 802.11g, it provides Direct Sequence Spread Spectrum (DSSS) operation for transparent bridging and roaming capabilities for wireless nodes. The TPE-S44 also provides WDS bridging functions, allowing users to connect two or more Access Points together, wirelessly. With this Wireless Access Point and Wireless Network Adapters, users can connect to Ethernet/Fast Ethernet LAN at home or office to access network resources with coverage up to 300 meters.
 - TRENDnet TPE-S44 - switch - 8 ports - TAA Compliant
 - Switch - 8 ports
- Subtype
 - Fast Ethernet
- Ports
 - 4 x 10/100 (PoE) + 4 x 10/100
- Power Over Ethernet (PoE)
 - PoE
- Performance
 - Switching capacity: 1.6 Gbps
- MAC Address Table Size
 - 1K entries
 - Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, PoE overcurrent protection, PoE circuit sorting protection
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
 - 17.1 cm x 9.8 cm x 2.9 cm
 - 430 g
- TAA Compliant
 - Limited lifetime warranty
 - Switch - 8 ports
- Enclosure Type
 - Desktop
- Subtype
 - Fast Ethernet
- Ports
 - PoE
- Performance
 - 1K entries
- Status Indicators
 - Port status, power, link/activity
 - 4 x 100Base-TX RJ-45 , 4 x 100Base-TX RJ-45 PoE - 15.4 W
- Power Device
 - External power adapter
 - 36.3 Watt
 - FCC
- TAA Compliant
 - 17.1 cm
 - 9.8 cm
 - 2.9 cm
 - 430 g
 - Limited warranty - lifetime
 - 0 °C
 - 40 °C
 - 10 - 90% (non-condensing)
- Min Storage Temperature
 - -10 °C
- Max Storage Temperature
 - 70 °C
