TRENDnet's 6-port Gigabit PoE+ switch reduces equipment and installation costs by delivering data and power over existing Ethernet cables. This small network switch with SFP support provides four Gigabit PoE+ ports with a total PoE power budget of 65W, one Gigabit port, and one SFP slot for fiber applications. With PoE technology, users only need one set of cables to deliver both data and power. The small network switch with SFP support allows you to network PoE devices such as wireless access points, IP cameras, VoIP phones, IP video encoders, access controls, and more. The added SFP slot supports both single mode and multi-mode fiber SFP modules for long-distance fiber networking applications.
PoE+ power
The small network switch with SFP support features a 65W total PoE power budget that supplies up to four power over Ethernet devices. -
6 Gigabit ports
Six Gigabit ports provide a full 12Gbps switching capacity to this small network switch with SFP support for edge network installations. -
Compact design
With a compact and lightweight housing design, this compact switch is well-suited for desktop installations. Its fanless design is perfect for quiet environments that require silent operation.
 - TRENDnet TPE TG611 - switch - 6 ports - TAA Compliant
 - Switch - 6 ports
- Subtype
 - Gigabit Ethernet
- Ports
 - 4 x 10/100/1000 (PoE+) + 1 x 10/100/1000 (uplink) + 1 x Gigabit SFP
- Power Over Ethernet (PoE)
 - PoE+
- PoE Budget
 - 65 W
- Performance
 - Switching capacity: 12 Gbps , Forwarding performance (64-byte packet size): 8.292 Mpps , Buffer memory: 128 KB
- MAC Address Table Size
 - 2K entries
- Jumbo Frame Support
 - 9KB
 - Half duplex mode, full duplex mode, wall mountable, fanless, CoS
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- Power
 - AC 120/230 V (50/60 Hz)
 - 19.3 cm x 8.4 cm x 2.6 cm
 - 456 g
- TAA Compliant
 - Limited lifetime warranty
 - Switch - 6 ports
- Enclosure Type
 - Desktop
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE+
- PoE Budget
 - 65 W
- Performance
 - 2K entries
 - 9KB
- Status Indicators
 - Port status
 - 4 x 1000Base-T RJ-45 PoE+ , 1 x 1000Base-T RJ-45 uplink , 1 x Gigabit LAN SFP
- Power Device
 - Internal power supply
- Power Provided
 - 55 V - 1.3 A
- Voltage Required
 - 71.5 Watt
- MTBF
 - 1,401,356 hours
 - FCC
- TAA Compliant
 - 19.3 cm
 - 8.4 cm
 - 2.6 cm
 - 456 g
 - Limited warranty - lifetime
 - 0 °C
 - 40 °C
 - 0 - 90% (non-condensing)
