TRENDnet 6-Port Gigabit PoE+ Switch
Quicklinx: FQ8VWS00 Mfr#: TPE-TG611
Type: Gigabit Ethernet
Ports: 6
POE: PoE+
£63.81 ex VAT
£76.57 inc VAT
TRENDnet's 6-port Gigabit PoE+ switch reduces equipment and installation costs by delivering data and power over existing Ethernet cables. This small network switch with SFP support provides four Gigabit PoE+ ports with a total PoE power budget of 65W, one Gigabit port, and one SFP slot for fiber applications. With PoE technology, users only need one set of cables to deliver both data and power. The small network switch with SFP support allows you to network PoE devices such as wireless access points, IP cameras, VoIP phones, IP video encoders, access controls, and more. The added SFP slot supports both single mode and multi-mode fiber SFP modules for long-distance fiber networking applications.
  • PoE+ power
    The small network switch with SFP support features a 65W total PoE power budget that supplies up to four power over Ethernet devices.
  • 6 Gigabit ports
    Six Gigabit ports provide a full 12Gbps switching capacity to this small network switch with SFP support for edge network installations.
  • Compact design
    With a compact and lightweight housing design, this compact switch is well-suited for desktop installations. Its fanless design is perfect for quiet environments that require silent operation.
TRENDnet TPE TG611 - switch - 6 ports - TAA Compliant
Switch - 6 ports
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE+) + 1 x 10/100/1000 (uplink) + 1 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
65 W
Performance
Switching capacity: 12 Gbps , Forwarding performance (64-byte packet size): 8.292 Mpps , Buffer memory: 128 KB
MAC Address Table Size
2K entries
Jumbo Frame Support
9KB
Half duplex mode, full duplex mode, wall mountable, fanless, CoS
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
19.3 cm x 8.4 cm x 2.6 cm
456 g
TAA Compliant
Switch - 6 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
65 W
Performance
2K entries
Jumbo Frame Support
9KB
Status Indicators
Port status
4 x 1000Base-T RJ-45 PoE+ , 1 x 1000Base-T RJ-45 uplink , 1 x Gigabit LAN SFP
Internal power supply
Power Provided
55 V - 1.3 A
71.5 Watt
MTBF
1,401,356 hours
FCC
TAA Compliant
19.3 cm
8.4 cm
2.6 cm
456 g
Limited warranty - lifetime
0 - 90% (non-condensing)
Ports: 6
POE: PoE+
Brand: TRENDnet
