Brand
TRENDnet 52-Port Gigabit Web Smart PoE+ Switch
Quicklinx: FQ8MWS00 Mfr#: TPE-5240WS
Type: Gigabit Ethernet
Ports: 52
Managed: Yes
POE: PoE+
£469.82 ex VAT
£563.78 inc VAT
TRENDnet's 52-Port Gigabit Web Smart PoE+ Switch, model TPE-5240WS, delivers advanced management features with a 104Gbps switching capacity. This rack mountable IPv6 ready switch comes with an intuitive web-based interface. Advanced traffic management controls, troubleshooting, and SNMP monitoring make this a powerful solution for SMB networks. The TPE-5240WS provides 48 gigabit PoE+ ports with a total power budget of 370 W, and four shared gigabit ports . The PoE+ standard supplies up to 30 W of power per port for devices such as high power wireless access points, PTZ (Pan Tilt Zoom) Internet cameras, and VoIP telephony systems.
  • Web smart management
    Provides an easy-to-use web-based GUI management for reduced switch configuration complexity and offers a combination of SMB management features for easy deployment.
  • Integration flexibility
    Managed features include access control lists, VLAN, IGMP snooping, QoS, RMON, SNMP trap, and syslog for monitoring and flexible network integration.
  • PoE power
    A 370W PoE power budget supplies power to PoE/PoE+ devices.
TRENDnet TPE 5240WS - switch - 52 ports - smart - rack-mountable
Switch - 52 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
370 W
Performance
Switching capacity: 104 Gbps , Forwarding performance (64-byte packet size): 77.4 Mpps
VLAN groups: 256
MAC Address Table Size
16K entries
Jumbo Frame Support
10KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, SNMP 3, SNMP 2c, HTTP, HTTPS
DHCP support, VLAN support, IGMP snooping, Syslog support, port mirroring, MAC address filtering, IPv6 support, half duplex mode, full duplex mode, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, LLDP support, Link Aggregation Control Protocol (LACP), Traffic Control, SNMP trap, Management Information Base (MIB), Dynamic VLAN Support (GVRP), Class of Service (CoS), Strict Priority (SP), tagged VLAN, Denial of Service (DoS), per port bandwidth control, 3 fans, 1.5MB packet buffer, Storm Control, port filtering, Static Link Aggregation, Voice VLAN, LLDP-MED, Private VLAN, Weighted Round Robin (WRR), Head-of-line (HOL) Blocking Prevention, loopback detection
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
AC 100 - 240 V (50/60 Hz)
44 cm x 43 cm x 4.4 cm
6.12 kg
Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
370 W
Performance
VLAN groups: 256
16K entries
Jumbo Frame Support
10KB
Routing Protocol
Encryption Algorithm
TLS, SSL 3.0, SSL 2.0
Authentication Method
RADIUS, TACACS+
Status Indicators
Power, PoE, link/activity, SFP
48 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x Gigabit LAN SFP , 4 x 1000Base-T RJ-45
Internal power supply
479 Watt
Rack Mounting Kit
Included
MTBF
239,897 hours
FCC, RoHS, WEEE
Software Included
Drivers & Utilities
44 cm
43 cm
4.4 cm
6.12 kg
Limited warranty - lifetime
-5 °C
50 °C
95% (non-condensing)
Ports: 52
Managed: Yes
POE: PoE+
Brand: TRENDnet
