TRENDnet 5-Port Gigabit PoE+ Powered EdgeSmart Switch
Quicklinx: FQ8QWS00 Mfr#: TPE-P521ES
5-Port Gigabit PoE+ Powered EdgeSmart Switch with PoE Pass Through, model TPE-P521ES, is powered by a PoE+ switch or injector, no AC adapter is required. It features two gigabit non-PoE ports, and two gigabit PoE ports to power devices such as IP cameras, VoIP handsets, and wireless access points. Reducing unnecessary switch complexity, this EdgeSmart switch is equipped with only the most commonly used managed switch features. The simple web-based user interface allows you to easily manage VLANs, QoS, and monitoring.
  • Integration flexibility
    Managed features include access control lists, VLAN, IGMP Snooping, and QoS for flexible network integration.
  • PoE+ powered
    No AC adapter required - this switch is powered by a PoE+ switch or injector, and features two gigabit non-PoE ports, and two gigabit PoE ports to power devices such as IP cameras.
  • EdgeSmart management
    Provides an easy to use web-based management interface for reduced switch configuration complexity and offers a combination of more commonly used SMB management features for easy deployment.
TRENDnet TPE P521ES - switch - 5 ports - smart - TAA Compliant
Switch - 5 ports - smart
Subtype
Gigabit Ethernet
Ports
1 x 10/100/1000 (PoE+ input) + 2 x 10/100/1000 (PoE) + 2 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
18 W
Performance
Switching capacity: 10 Gbps , Forwarding rate: 7.44 Mpps
VLAN groups: 32 , Multicast groups: 32
MAC Address Table Size
2K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP
IGMP snooping, port mirroring, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, firmware upgradable, WFQ, wall mountable, STP support, RSTP support, reset button, bandwidth control, fanless, short circuit protection, CoS, SP, tagged VLAN, metal housing, PoE overcurrent protection, cable test, Voice VLAN, Private VLAN, loopback detection, port-based VLAN, port-based QoS, block unknown multicast, PoE powered, Asymmetric VLAN, PoE Pass Through
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3at, IEEE 802.3az
15 cm x 9.7 cm x 2.86 cm
370 g
TAA Compliant
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
18 W
Performance
2K entries
Jumbo Frame Support
9KB
Routing Protocol
RAM
512 KB
Status Indicators
Power, PoE, link/activity
1 x Gigabit LAN RJ-45 PoE+ / input - 30 W , 2 x Gigabit LAN RJ-45 PoE - 15.4 W , 2 x Gigabit LAN RJ-45
Power Provided
30 Watt
20.4 Watt
MTBF
730,455 hours
FCC, RoHS, WEEE
TAA Compliant
15 cm
9.7 cm
2.86 cm
370 g
Limited warranty - lifetime
90% (non-condensing)
