This sturdy metal switch is ideal for reliable high-speed PoE networking. Its fanless design is perfect for quiet environments that require silent operation.
- TRENDnet TPE LG50 - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 4 x 10/100/1000 (PoE+) + 1 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 32 W
- Performance
- Switching capacity: 10 Gbps , Forwarding performance (64-byte packet size): 7.44 Mpps
- MAC Address Table Size
- 2K entries
- Jumbo Frame Support
- 9KB
- VLAN support, half duplex mode, full duplex mode, wall mountable, Quality of Service (QoS), fanless, built-in DIP switch, port isolation, Class of Service (CoS), metal housing, long range PoE+ up to 200m at 10Mbps
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3p, IEEE 802.3at
- Power
- AC 120/230 V (50/60 Hz)
- 12.1 cm x 7.5 cm x 2.6 cm
- 246 g
- Limited lifetime warranty
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 32 W
- Performance
- 2K entries
- 9KB
- RAM
- 128 KB
- Status Indicators
- Power, alert, PoE, link/activity, link/speed
- 4 x Gigabit LAN RJ-45 PoE+ , 1 x Gigabit LAN RJ-45
- Power Device
- External power adapter
- Power Provided
- 54 V - 0.7 A
- Voltage Required
- 36.3 Watt
- Plug and Play, FCC, RoHS, WEEE
- 12.1 cm
- 7.5 cm
- 2.6 cm
- 246 g
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
