The 5-Port 10/100 Mbps PoE Switch, model TPE-S50, delivers data and power over existing Ethernet cables to Power over Ethernet (PoE) devices such as Access Points and IP Cameras. The TPE-S50 offers four 10/100 Mbps PoE Ethernet ports and one 10/100 Mbps Ethernet port. It supports PoE (802.3af) devices with a 31 Watt power budget. Plug and Play this sturdy metal switch for reliable high speed PoE networking.
PoE camera flexibility
Automatically supply up to 15.4 Watts to standard 802.3af PoE devices. -
PoE power
A 31 Watt PoE power budget supplies up to four Power over Ethernet devices with PoE power. -
Ethernet networking
Five 10/100 Mbps Ethernet ports produce a 1 Gbps switching capacity to support edge network installations.
 - TRENDnet TPE S50 - switch - 5 ports - unmanaged
 - Switch - 5 ports - unmanaged
- Subtype
 - Fast Ethernet
- Ports
 - 4 x 10/100 (PoE) + 1 x 10/100
- Power Over Ethernet (PoE)
 - PoE
- PoE Budget
 - 31 W
- Performance
 - Switching capacity: 1 Gbps , Forwarding performance (64-byte packet size): 0.744 Mpps
- MAC Address Table Size
 - 1K entries
 - Half duplex mode, full duplex mode, GREENnet technology, 56KB packet buffer, metal housing
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
- Power
 - AC 120/230 V (50/60 Hz)
 - 14.1 cm x 9.5 cm x 3 cm
 - 337 g
 - Limited lifetime warranty
- Enclosure Type
 - Desktop
- Subtype
 - Fast Ethernet
- Ports
 - PoE
- PoE Budget
 - 31 W
- Performance
 - 1K entries
- Status Indicators
 - Power, PoE, link/activity
 - 4 x 100Base-TX RJ-45 PoE - 15.4 W , 1 x 100Base-TX RJ-45
- Power Device
 - External power adapter
- Voltage Required
 - 36 Watt
 - FCC, RoHS
 - 14.1 cm
 - 9.5 cm
 - 3 cm
 - 337 g
 - Limited warranty - lifetime
 - 0 °C
 - 40 °C
 - 0 - 90% (non-condensing)
