TRENDnet 5-Port 10/100Mbps PoE Switch (31W)
Quicklinx: FQ8ZWS00 Mfr#: TPE-S50
The 5-Port 10/100 Mbps PoE Switch, model TPE-S50, delivers data and power over existing Ethernet cables to Power over Ethernet (PoE) devices such as Access Points and IP Cameras. The TPE-S50 offers four 10/100 Mbps PoE Ethernet ports and one 10/100 Mbps Ethernet port. It supports PoE (802.3af) devices with a 31 Watt power budget. Plug and Play this sturdy metal switch for reliable high speed PoE networking.
  • PoE camera flexibility
    Automatically supply up to 15.4 Watts to standard 802.3af PoE devices.
  • PoE power
    A 31 Watt PoE power budget supplies up to four Power over Ethernet devices with PoE power.
  • Ethernet networking
    Five 10/100 Mbps Ethernet ports produce a 1 Gbps switching capacity to support edge network installations.
TRENDnet TPE S50 - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Fast Ethernet
Ports
4 x 10/100 (PoE) + 1 x 10/100
Power Over Ethernet (PoE)
PoE
PoE Budget
31 W
Performance
Switching capacity: 1 Gbps , Forwarding performance (64-byte packet size): 0.744 Mpps
MAC Address Table Size
1K entries
Half duplex mode, full duplex mode, GREENnet technology, 56KB packet buffer, metal housing
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
14.1 cm x 9.5 cm x 3 cm
337 g
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
PoE
PoE Budget
31 W
Performance
1K entries
Status Indicators
Power, PoE, link/activity
4 x 100Base-TX RJ-45 PoE - 15.4 W , 1 x 100Base-TX RJ-45
External power adapter
36 Watt
FCC, RoHS
14.1 cm
9.5 cm
3 cm
337 g
Limited warranty - lifetime
0 - 90% (non-condensing)
