TRENDnet 48-Port Gigabit POE+ Managed Layer 2 Switch
Quicklinx: FQ8HWS00 Mfr#: TL2-PG484
TRENDnet's 48-Port Gigabit PoE+ Managed Layer 2 Switch with 4 shared SFP slots, model TL2-PG484, has 24 x Gigabit PoE+ ports, 24 x Gigabit ports, and 4 x shared SFP slots, a console port, a PoE Power budget of 370 Watts, and an advanced Layer 2 management feature set. This IPv6 ready switch offers traffic management, troubleshooting, access control, and monitoring features.
  • Power over Ethernet
    The 370 W PoE power budget supplies PoE+ (up to 30 W) to ports 1-24 along with PD (powered device) auto classification and over current/short circuit protection.
  • Smart fans
    Smart fans save energy and reduce operating noise by varying fan speed and usage based on real-time cooling needs.
  • Integration flexibility
    Managed features include access control lists, VLAN, IGMP snooping, QoS, RMON, SNMP trap and syslog for monitoring and flexible network integration.
TRENDnet TL2 PG484 - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 24 x 10/100/1000 (PoE+) + 4 x shared Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
370 W
Performance
Switching capacity: 96 Gbps , Forwarding performance (64-byte packet size): 71.4 Mpps
VLAN groups: 256
MAC Address Table Size
16K entries
Jumbo Frame Support
10KB
Remote Management Protocol
SNMP 1, SNMP 2c, SNMP 3, RMON 1, HTTP, HTTPS, SSH-2, CLI, Telnet
VLAN support, QoS, bandwidth control, trunking, port mirroring, MSTP support, RSTP support, reset button, full duplex mode, half duplex mode, 1MB packet buffer, IPv6 support, CoS, DSCP support, WRR queuing, tagged VLAN, GVRP, MLD snooping, IGMP snooping, DoS, Loopback, PoE overcurrent protection, short circuit protection
IEEE 802.1ab (LLDP), IEEE 802.1D, IEEE 802.1p, IEEE 802.1Q, IEEE 802.1s, IEEE 802.1w, IEEE 802.1x, IEEE 802.3, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.3az, IEEE 802.3u, IEEE 802.3x, IEEE 802.3z, ANSI T1.102, IEEE 802.3af, IEEE 802.3at
44 cm x 43 cm x 4.445 cm
6.61 kg
Microsoft Windows 7 / 8.1 / 10, Windows 8, Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows Vista / XP, Microsoft Windows Vista / XP / 7
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
370 W
Performance
VLAN groups: 256
16K entries
Jumbo Frame Support
10KB
Encryption Algorithm
SSL 2.0, SSL 3.0, TLS
Authentication Method
RADIUS
Built-in Devices
Led panel
24 x 1000Base-T RJ-45 , 4 x SFP , 1 x console RJ-45 management , 24 x 1000Base-T RJ-45 PoE+ - 30 W
Internal power supply
Rack Mounting Kit
Included
MTBF
318,350 hours
FCC, UL
44 cm
43 cm
4.445 cm
6.61 kg
Limited warranty - lifetime
45 °C
90% (non-condensing)
