The 4-port PS/2 Audio KVM Switch lets you control multimedia PCs with just one keyboard, monitor, mouse, microphone and a set of speakers. The KVM switch not only allows you to share your monitor, keyboard and mouse but you can also share microphone and speakers. With just a simple press of a button, this KVM switch eliminates the hassle of cable swapping and switching between 4 PCs. With its Hot-Plug, Auto-Scan and Hot-Key operating features, the TK-408K is the perfect choice for managing 4 PCs. Separate KVM cables are included.
- TRENDnet TK 408K - KVM / audio switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Users Qty
- 1 local user
- 16.7 cm x 8 cm x 2.8 cm
- 178 g
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 2048 x 1536
- 4 x mouse (PS/2) , 4 x keyboard (PS/2) , 4 x VGA HD-15 , 4 x audio mini-jack , 4 x microphone mini-jack , 1 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x audio mini-jack , 1 x microphone mini-jack
- Cables Included
- 4 x keyboard / mouse / video cable , 4 x audio cable
- RoHS
- 16.7 cm
- 8 cm
- 2.8 cm
- 178 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90%
