TRENDnet 300Mbps Wireless N Gaming Adapter
Quicklinx: 82P3WS00 Mfr#: TEW-647GA
  • IEEE 802.11n (draft 2.0)
The Wireless N Gaming Adapter (TEW-647GA) connects your favorite Ethernet-ready gaming console to a lag-free wireless N network. No need to locate your gaming station near an Internet connection - cut your cables and start winning with high-performance wireless N. Setup is quick and simple, with no drivers to install. It works with Nintendo Wii, Xbox, Xbox 360 and PlayStation 2 and 3. Connect multiple gaming consoles wirelessly and play head-to-head or challenge others over the Internet in multiplayer mode.
The wireless encryption ensures wireless security. Advanced Multiple Input Multiple Output (MIMO) antenna technology reduces wireless dead spots. Wireless Protected Setup (WPS) lets you integrate other WPS devices into your secured network quickly.
TRENDnet TEW 647GA Wireless N Gaming Adapter - radio access point - Wi-Fi
Radio access point
External
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Vista
Environmental Standards
ENERGY STAR Qualified
10 cm x 7 cm x 2 cm
80 g
3-year warranty
Radio access point
10 cm
7 cm
2 cm
80 g
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz
Max Range Indoors
50 m
Max Range Open Space
100 m
Status Indicators
Port status, power, status
Hardware encryption, MIMO technology, Wi-Fi Protected Setup (WPS)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
1 x 100Base-TX - RJ-45
1 x network cable - 60 cm
FCC, RoHS
ENERGY STAR Certified
External power adapter
Limited warranty - 3 years
5 - 95%
