TRENDnet 24-port GREENnet Gigabit PoE+ Switch (370W)
Quicklinx: FQ8YWS00 Mfr#: TPE-TG240g
TRENDnet’s 24-Port Gigabit PoE+ Switch, model TPE-TG240g, offers 24 x Gigabit PoE+ ports, a 48 Gbps switching capacity, and a PoE power budget of 370 Watts.
  • PoE camera flexibility
    The switch recognizes non-PoE, PoE (15.4 W), and PoE+ (30 W) cameras (or other PoE devices) and supplies the required amount of power automatically.
  • Full PoE power
    The large 370 Watt PoE power budget supplies full PoE power to every port, thereby maximizing the number of allowable connected PoE devices.
  • Gigabit networking
    All Gigabit ports produce a 48 Gbps switching capacity and support Jumbo Frames up to 10 KB.
TRENDnet TPE TG240g - switch - 24 ports - rack-mountable - TAA Compliant
Switch - 24 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
370 W
Performance
Switching capacity: 48 Gbps , Forwarding performance (64-byte packet size): 35.7 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Rugged, PoE overcurrent protection, PoE circuit sorting protection
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
44 cm x 25 cm x 4.4 cm
3.6 kg
TAA Compliant
Switch - 24 ports
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
370 W
Performance
8K entries
Jumbo Frame Support
10KB
RAM
512 KB
Status Indicators
Power, PoE, link/activity, fan
24 x 1000Base-T RJ-45 30 W
Internal power supply
36 Watt
Rack Mounting Kit
Included
FCC
TAA Compliant
44 cm
25 cm
4.4 cm
3.6 kg
Limited warranty - lifetime
0 - 90% (non-condensing)
