The 24-Port Gigabit GREENnet Switch, model TEG-S24Dg, provides high bandwidth performance, ease of use and reliability, all while reducing power consumption by up to 70% .
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings. Embedded GREENnet technology works right out of the box with no management requirement.
Boost office network efficiency and eliminate network congestion with Gigabit speeds and a total switching capacity of 48Gbps with full-duplex mode. A built in universal power supply reduces cable clutter and diagnostic LEDs help with network troubleshooting. Plug and Play this sturdy metal switch for reliable high-speed network connectivity.
- TRENDnet TEG S24Dg - switch - 24 ports - TAA Compliant
- Switch - 24 ports
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000
- Performance
- Switching fabric bandwidth: 48 Gbps
- MAC Address Table Size
- 8K entries
- Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), packet filtering, store and forward, GREENnet technology, Jumbo Frames support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 28 cm x 18 cm x 4.4 cm
- 1.7 kg
- TAA Compliant
- Limited lifetime warranty
- Switch - 24 ports
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000
- Performance
- 8K entries
- RAM
- 512 KB
- Built-in Devices
- Led panel
- Status Indicators
- Port transmission speed, power, link/activity
- 24 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 13 Watt
- Cables Included
- 1 x power cable
- Plug and Play, FCC
- TAA Compliant
- 28 cm
- 18 cm
- 4.4 cm
- 1.7 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
