TRENDnet's 1620WSF offers advanced L2+ features with enhanced traffic management controls to meet the evolving demands of SMB networks. This rack mountable IPv6-ready managed switch comes with an intuitive web-based interface. Advanced managed switch features include LACP to group ports together to increase bandwidth between switches, VLANs for segmenting and isolating virtual LAN groups, QoS for traffic prioritization, port bandwidth controls, and SNMP monitoring, making this a powerful solution for SMB networks. Improve voice performance by isolating and prioritizing VoIP traffic from normal data traffic with the easy to use voice VLAN feature.
Integration flexibility
Managed switch features include access control lists, VLAN, IGMP/MLD snooping, QoS, RMON, SNMP trap, and syslog for monitoring and flexible network integration. -
Web smart management
Provides an easy-to-use web-based management interface for reduced switch configuration complexity and offers a combination of SMB management features for easy deployment. -
Dynamic ARP inspection
Dynamic ARP inspection feature helps protect connected devices from man-in-the-middle attacks by discarding malicious and invalid ARP packets.
- TRENDnet TPE 1620WSF - switch - 20 ports - smart - rack-mountable - TAA Compliant
- Switch - 20 ports - L2+ - smart
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000 (PoE+) + 4 x shared Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 370 W
- Performance
- Switching capacity: 40 Gbps , Forwarding performance (64-byte packet size): 29.8 Mpps
- Capacity
- VLAN groups: 256
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 10KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3, static IPv6 routing
- Remote Management Protocol
- SNMP 1, RMON 1, SNMP 3, SNMP 2c, HTTP, HTTPS
- DHCP support, VLAN support, port mirroring, WRR queuing, MAC address filtering, IPv6 support, GREENnet technology, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, Jumbo Frames support, reset button, bandwidth control, LLDP support, LACP, MIB, 512KB packet buffer, GVRP, NAC, SPQ, NDP, CoS, tagged VLAN, Loopback, DoS, Duplicated Address Detection, Smart Fans
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 25 cm x 4.4 cm
- 3.89 kg
- TAA Compliant
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 370 W
- Performance
- Capacity
- VLAN groups: 256
- 8K entries
- 10KB
- Routing Protocol
- Encryption Algorithm
- TLS, SSL 3.0, SSL 2.0
- Authentication Method
- RADIUS, TACACS+
- Status Indicators
- Power, PoE, link/activity
- 16 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x Gigabit LAN RJ-45/SFP
- Power Device
- Internal power supply
- Voltage Required
- 460 Watt
- Rack Mounting Kit
- Included
- MTBF
- 192,382 hours
- FCC, RoHS, WEEE
- TAA Compliant
- 44 cm
- 25 cm
- 4.4 cm
- 3.89 kg
- Limited warranty - lifetime
- -5 °C
- 50 °C
- 0 - 90% (non-condensing)
