TRENDnet 20-port Gigabit Web Smart POE+ Switch
Quicklinx: FQ8KWS00 Mfr#: TPE-1620WSF
TRENDnet's 1620WSF offers advanced L2+ features with enhanced traffic management controls to meet the evolving demands of SMB networks. This rack mountable IPv6-ready managed switch comes with an intuitive web-based interface. Advanced managed switch features include LACP to group ports together to increase bandwidth between switches, VLANs for segmenting and isolating virtual LAN groups, QoS for traffic prioritization, port bandwidth controls, and SNMP monitoring, making this a powerful solution for SMB networks. Improve voice performance by isolating and prioritizing VoIP traffic from normal data traffic with the easy to use voice VLAN feature.
  • Integration flexibility
    Managed switch features include access control lists, VLAN, IGMP/MLD snooping, QoS, RMON, SNMP trap, and syslog for monitoring and flexible network integration.
  • Web smart management
    Provides an easy-to-use web-based management interface for reduced switch configuration complexity and offers a combination of SMB management features for easy deployment.
  • Dynamic ARP inspection
    Dynamic ARP inspection feature helps protect connected devices from man-in-the-middle attacks by discarding malicious and invalid ARP packets.
TRENDnet TPE 1620WSF - switch - 20 ports - smart - rack-mountable - TAA Compliant
Switch - 20 ports - L2+ - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 (PoE+) + 4 x shared Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
370 W
Performance
Switching capacity: 40 Gbps , Forwarding performance (64-byte packet size): 29.8 Mpps
VLAN groups: 256
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON 1, SNMP 3, SNMP 2c, HTTP, HTTPS
DHCP support, VLAN support, port mirroring, WRR queuing, MAC address filtering, IPv6 support, GREENnet technology, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, Jumbo Frames support, reset button, bandwidth control, LLDP support, LACP, MIB, 512KB packet buffer, GVRP, NAC, SPQ, NDP, CoS, tagged VLAN, Loopback, DoS, Duplicated Address Detection, Smart Fans
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 25 cm x 4.4 cm
3.89 kg
TAA Compliant
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
370 W
Performance
VLAN groups: 256
8K entries
Jumbo Frame Support
10KB
Routing Protocol
Encryption Algorithm
TLS, SSL 3.0, SSL 2.0
Authentication Method
RADIUS, TACACS+
Status Indicators
Power, PoE, link/activity
16 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x Gigabit LAN RJ-45/SFP
Internal power supply
460 Watt
Rack Mounting Kit
Included
MTBF
192,382 hours
FCC, RoHS, WEEE
TAA Compliant
44 cm
25 cm
4.4 cm
3.89 kg
Limited warranty - lifetime
-5 °C
50 °C
0 - 90% (non-condensing)
