Brand
TRENDnet 16-Port Gigabit GREENnet Desktop Switch
Quicklinx: 9YKSWS00 Mfr#: TEG-S16Dg
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: 1Gbps
Managed: No
POE: No
£57.09 ex VAT
£68.50 inc VAT
The 16-Port Gigabit GREENnet Switch, model TEG-S16Dg, provides high bandwidth performance, ease of use, and reliability, all while reducing power consumption by up to 70%.
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings. Embedded GREENnet technology works right out of the box with no management requirement.
Boost office network efficiency and eliminate network congestion with Gigabit speeds and a total switching capacity of 32Gbps with full-duplex mode. A built in universal power supply reduces cable clutter and diagnostic LEDs help with network troubleshooting. Plug and Play this sturdy metal switch for reliable high-speed network connectivity.
TRENDnet TEG S16Dg - switch - 16 ports
Switch - 16 ports
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Switching fabric bandwidth: 32 Gbps
MAC Address Table Size
8K entries
Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), packet filtering, store and forward, GREENnet technology, Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
28 cm x 18 cm x 4.4 cm
450 g
3-year warranty
Switch - 16 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
8K entries
RAM
2 MB
Built-in Devices
Led panel
Status Indicators
Port transmission speed, power, link/activity
16 x 1000Base-T RJ-45
Internal power supply
1 x power cable - 1.8 m
Plug and Play, FCC
28 cm
18 cm
4.4 cm
450 g
Limited warranty - 3 years
0 - 90% (non-condensing)
Ports: 16
Managed: No
POE: No
Brand: TRENDnet
