TRENDnet 16-port Cat6 Unshielded Patch Panel
Quicklinx: 9YPHWS00 Mfr#: TC-P16C6
Prepare yourself for Copper Gigabit Ethernet with TRENDnet's Cat. 6 RJ-45 UTP Patch Panels. These patch panels are certified for 250Mhz Category 6, which are perfect for Copper Gigabit Ethernet connections. TRENDnet's 16/24/48-port Cat. 6 Patch Panels are ideal for Ethernet, Fast Ethernet and Copper Gigabit Ethernet (1000Base-T) network applications. Using TRENDnet's Cat. 6 products now, will prepare you for the high bandwidth network in the future without re-cabling your network.
TRENDnet patch panel
Patch panel - CAT 6
Port Qty
16 ports
Wiring Scheme
T568B
UL
1-year warranty
Patch panel - CAT 6
Cabling & Wiring
Port Qty
16 ports
Termination Type
110 type termination
Wiring Scheme
T568B
Connector Provided
16 x RJ-45 female
UL
Limited warranty - 1 year
-40 °C
80 °C
