The 150Mbps mobile wireless N router connects to the Internet either using a traditional hard wired connection or by cutting the cables and connecting with a compatible wireless mobile USB dongle from a 3G Internet service provider.
Designed for true portability the router has a rechargeable and replaceable 2.5 hour lithium ion battery. Compatible with USB dongles from every mobile provider, this compact router connects to the Internet anywhere there is a 3G mobile connection.
No installation is required, simply plug the 3G USB adapter into the router to share a single Internet connection. The wireless encryption protects your valuable data. Wi-Fi Protected Setup (WPS) integrates other WPS supported clients at the touch of a button. An on/off switch on the back of the devices saves battery life.
- TRENDnet TEW-655BR3G - wireless router - Wi-Fi - desktop
- Wireless router
- Enclosure Type
- Desktop
- Mobile Communication Protocol
- CDMA 2000, UMTS, TD-SCDMA, WCDMA, HSPA
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 150 Mbps
- PPTP, L2TP, PPPoE
- Routing Protocol
- RIP-1, RIP-2
- Remote Management Protocol
- HTTP
- Firewall protection, DMZ port, NAT support, auto-uplink (auto MDI/MDI-X), SPI, DoS attack prevention, dynamic DNS server, MAC address filtering, URL filtering, IP address filtering, MIMO technology, event log, QoS, virtual server support, WPS
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n (draft 2.0), UPnP
- 7.6 cm x 10.7 cm x 2.1 cm
- 97.4 g
- 3-year warranty
- Wireless router
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 150 Mbps
- PPTP, L2TP, PPPoE
- Routing Protocol
- RIP-1, RIP-2
- HTTP
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n (draft 2.0), UPnP, FCC, RoHS
- Status Indicators
- Port status, power, link/activity
Line Properties
- Line Coding Format
- CCK, BPSK, QPSK, OFDM
Communications
- WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
- Power Device
- External power adapter
- 7.6 cm
- 10.7 cm
- 2.1 cm
- 97.4 g
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 0 - 95%
