TRENDnet 150MBPS Wireless N 3G Router
Quicklinx: B4FWWS00 Mfr#: TEW-655BR3G
Type: Wireless router
Connection Type: [N/A]
Standards: IEEE 802.11b, IEEE 802.11g, Fast Ethernet, IEEE 802.11n (draft 2.0) + 1 more
Speed: 150Mbps
Rackmount or External: External
  • IEEE 802.11n (draft 2.0)
£54.99 ex VAT
£65.98 inc VAT
The 150Mbps mobile wireless N router connects to the Internet either using a traditional hard wired connection or by cutting the cables and connecting with a compatible wireless mobile USB dongle from a 3G Internet service provider.
Designed for true portability the router has a rechargeable and replaceable 2.5 hour lithium ion battery. Compatible with USB dongles from every mobile provider, this compact router connects to the Internet anywhere there is a 3G mobile connection.
No installation is required, simply plug the 3G USB adapter into the router to share a single Internet connection. The wireless encryption protects your valuable data. Wi-Fi Protected Setup (WPS) integrates other WPS supported clients at the touch of a button. An on/off switch on the back of the devices saves battery life.
TRENDnet TEW-655BR3G - wireless router - Wi-Fi - desktop
Wireless router
Enclosure Type
Desktop
Mobile Communication Protocol
CDMA 2000, UMTS, TD-SCDMA, WCDMA, HSPA
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
HTTP
Firewall protection, DMZ port, NAT support, auto-uplink (auto MDI/MDI-X), SPI, DoS attack prevention, dynamic DNS server, MAC address filtering, URL filtering, IP address filtering, MIMO technology, event log, QoS, virtual server support, WPS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n (draft 2.0), UPnP
7.6 cm x 10.7 cm x 2.1 cm
97.4 g
3-year warranty
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
PPTP, L2TP, PPPoE
Routing Protocol
RIP-1, RIP-2
HTTP
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n (draft 2.0), UPnP, FCC, RoHS
Status Indicators
Port status, power, link/activity
Line Properties
Line Coding Format
CCK, BPSK, QPSK, OFDM
Communications
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
External power adapter
7.6 cm
10.7 cm
2.1 cm
97.4 g
Limited warranty - 3 years
45 °C
0 - 95%
Standards: IEEE 802.11g
Standards: Fast Ethernet
Standards: IEEE 802.11n (draft 2.0)
Standards: Ethernet
Speed: 150Mbps
Brand: TRENDnet
