TRENDnet 150Mbps Micro Wireless N USB Adapter
Quicklinx: 82NYWS00 Mfr#: TEW-648UBM
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11n, IEEE 802.11g
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
£7.93 ex VAT
£9.51 inc VAT
The 150Mbps micro wireless N USB adapter (model TEW-648UBM) quickly connects a laptop or desktop computer to a high speed wireless N network.
Enjoy proven wireless N speed and reliability, in a micro design that extends less than three eighths of an inch (9mm) from the edge of a computer. Connecting to a network is made easy with the external one-touch Wi-Fi Protected Setup (WPS) button. Advanced wireless encryption protects your valuable data. Wi-Fi Multimedia (WMM) Quality of Service (QoS) prioritizes important video, audio, and gaming traffic. Seamlessly stream video, download files, and play games with this ultra compact wireless n adapter.
USB 2.0 connector
Ultra compact form factor
Wi-Fi compliant with IEEE 802.11n standard
One-touch wireless connection with external Wi-Fi Protected Setup (WPS) button
Backwards compatible with IEEE 802.11g and IEEE 802.11b devices
Maximum reliability, throughput, and connectivity with automatic data rate switching
Supports 64/128-bit WEP, WPA/WPA2-RADIUS, and WPA-PSK/WPA2-PSK
Wi-Fi Multimedia (WMM) Quality of Service (QoS) data prioritization
Easy user setup and intuitive diagnostic utility
Coverage of up to 30 meters indoor (98 feet) and 50 meters outdoor (164 feet) *
3-year limited warranty
TRENDnet TEW-648UBM - network adapter - USB 2.0 - TAA Compliant
Network adapter
External
Interface (Bus) Type
USB 2.0
2 cm x 0.7 cm x 1.5 cm
1 g
802.11b/g/n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, USB 2.0, IEEE 802.11n
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions)
Microsoft Certification
Compatible with Windows 7
TAA Compliant
3-year warranty
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Spread Spectrum Method
OFDM, DSSS
Data Transfer Rate
150 Mbps
Line Coding Format
OFDM
Frequency Band
2.4 GHz
Max Range Indoors
30 m
Max Range Open Space
100 m
Status Indicators
Link/activity
Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
ETSI, FCC
TAA Compliant
Software Included
Drivers & Utilities
2 cm
0.7 cm
1.5 cm
1 g
Limited warranty - 3 years
0 - 95% (non-condensing)
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Compatibility: PC
Brand: TRENDnet
